Intergrated or pre combo question
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by BLACK_MAGIC, Jun 1, 2004.
  1. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    604
    manchester
    I'm currently seperating my home cinema and hifi sytems into two and have become unsure on the next step forward for my hifi system. I used to use an arcam av8 (in direct mode) for my stereo duties but that moved along with my home cinema setup.
    I have left so far for my hifi 1 pair of kef ref 203's and a chord spm 1200c. Now the problem i have is what do i use as the pre amp?. I've looked at the two first options as they are both the same price. I can go for the chord cpa2200 pre amp or the chord cpm2600 intergrated amp and use this to also biamp my speakers.
    As ive said they are both the same price but what im curious to know is what would be the better option or the general concensus to which is preferable in this case.
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I couldnt honestly say which is better since I have never heard, but my gut feeling is that the integrated amp biamping would give better performance. On the downside, it definitely offers a more closed upgrade path. If you went for the pre then you could simply add another power amp, with the integrated that approach has much less merit and in the future you may end up upgrading the integrated to get the pre and an additional power amp....
    Ad
  3. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    604
    manchester
    Thanks for the input buns
