Interference when arial is connected
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Blackhole68, Feb 5, 2009.
  1. Blackhole68
    Blackhole68
    Jan 30, 2009
    9
    I have wired up an ordinary Skybox but when I connect the arial I get lines across the sky picture although the analogue channels are ok. Take the arial out and the Sky picture is perfect. Any ideas?
  2. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    What picture on what TV?
  3. Geofbob
    Geofbob
    Jun 15, 2005
    2,293
    83
    +304
    What happens if you connect the aerial direct to the TV? If there are still lines on the Sky picture, this would indicate that the fault lies in the TV, not the Sky box.
  4. Blackhole68
    Blackhole68
    Jan 30, 2009
    9
    The skybox is in the roofspace and is connected to the TV via the coax cable, not scart. There is a magic eye at the TV. The picture is fine when I connect up the old skybox so the TV is ok.
  5. Blackhole68
    Blackhole68
    Jan 30, 2009
    9
    When the arial is disconnected from the skybox the sky picture is good but the minute I stick the arial in I get interference on the sky picture (lines across screen).
  6. hog
    hog
    Jan 15, 2005
    380
    28
    +36
    sounds like you need to change the rf output of the box to a clear channel number ?
