Interference on TV caused by speakers or amp
Discussion in 'Home Cinema Speakers' started by jimcarney, Feb 22, 2001.
  1. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    I have KEF 55.2s ,KEF95c, REGA Vulcan &
    Denon 1800 amp Just recently I have started
    getting colour casts in the bottom left corner & top right, the 55s are at least
    3ft either side of the TV & the sub is about
    4ft away ,can anybody out there help
    p.s. Anybody any comments on REGA ?
  2. Arthur.S
    Arthur.S
    Jim, where's your centre positioned? This sounds like problems caused by un-shielded speakers. Try taking your speakers right away from your TV one at a time. It's a pain, but you'll probably have to switch the telly off & back on again each time to be sure.
    www.baldyplex.com
  3. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Arthur,
    All the speakers are supposed to be sheilded,I have had the centre since July along with the amp ,I used to use a pair of
    HB1s I have had since they where fist out and they where closer than the 55s are now .
    They gave no problems unless they next to TV,and where unsheilded also I have sent emails to KEF and have had no reply.
    thanks for your suggestions will try later.
    Jim
