Interference (horizontal lines)
Discussion in 'Projectors, Screens & Video Processors' started by gjermund25, Sep 10, 2003.
  1. gjermund25
    gjermund25
    PLEASE!!!
    Can anyone help me...
    I have a projector and I'm having problems with horizontal lines moving up and down te screen. It is connected to my VCR.
    I think it's the aerial antenna (cable tv) wich is causing the problem. If watching a video with the antenna cable connected to the VCR I have the lines. If I take it out the lines dissapear. What can I do. I want to wach TV on my projector also, and that is impossible without the antenna connected. I have tried several VCR's with both s-vhs and composite. I get the same problem on every one of them.
    Anyone knows how to solve it?
    Mvh,
    Gjermund
  2. DowNtimE
    DowNtimE
    It seems to be a grounding problem. Not sure about the name of the gadget, but it's a galvanic diverter something, it could help with your problem. You should connect it to your antenna cable.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    You need a ground breaker that fits in line with your cable f-type. Tributaries in USA sell them. A decent aerial installation or satellite specialist will probably have them in stock as might RS or Maplins.
    Gordon
