interference from power lead ?
Discussion in 'Home Cinema Building DIY' started by Desf222, Sep 1, 2007.
  1. Desf222
    Desf222
    Dec 8, 2006
    5
    Hi everyone am fitting an lcd{sony kdl 20s2030} to chimney breast in bedroom and want to run aireal lead and power cable for tv in same conduit will there be any interfernce on the pic? Have asked at 2 local store 1 said yes 1 said no.Also am i right in thinking that it would be best too run coax straight into tv from loft aireal? no sockets. Also this might sound a dumb question but hay somone has to ask it even if it gives all you hardcore diyers a laugh but how long do the bolts for the tv bracket need to be, a bit worried about drilling through wall into chimney cavity.
  2. lochie
    lochie
    Jun 18, 2007
    87
    11
    Sutton Coldfield West Midlands
    +7
    Hi ,
    OK I'll make stab .
    and want to run aireal lead and power cable for tv in same conduit will there be any interfernce on the pic? -
    Not recommended - but personally if you have good coax don't think it is a problem over a short run.
    Yes this is what is recommended - you lose some signal strengh with sockets. But I guess if you have good signal to start than then a little loss my not be problem. Also if you using for FreeView then you should check all channels work ok. I think this all depends where you live in relation to the transmitter. Again personally , I tested mine - arail in loft with socket on the wall ran a standard wire from scoket to sceen work ok for me. not perfect for some channels.
    Depends on the weight of the screen - LCD is light, But you still need to go good distance. I am guessing the 20 inch lcd is lighter than my 27 inch which is nothing compared to the plasma. I think you got get away with 2 inchs into the wall
    lochie
