Interference from laptop help?
Discussion in 'AV Receivers & Amplifiers' started by Smeeble, Jun 17, 2009.
  1. Smeeble
    Smeeble
    Jul 16, 2008
    468
    Wirral
    +78
    Hello, I am getting bad interference from my laptop through my amplifier. It doesn't happen if I disconnect either the mains power or the audio cable so I think it is the transformer. I have the 3 pin laptop power which has the earth connection which I have read somewhere can cause this problem.
    Would a 2 pin power cable for my laptop solve this or does anyone else have ideas?
    Thank you.
