interference from DVD player.
Discussion in 'Cables & Switches' started by schmeegle, Feb 27, 2005.
  1. schmeegle
    schmeegle
    I recently got a scart switcher to be able to get 3 components plugged into 1 socket.
    It all works really well apart from there being a bit of interference when watching a DVD. It's as if there are 2 signals being sent to the TV, the second being very faint and a bit off centre.
    Does anyone have any ideas how I can fix this? No such problem on the other 2 components.
    Thanks! :thumbsup:
  2. Filbert
    Filbert
    Apr 6, 2004
    962
    46
    Pinner
    +195
    Sounds to me like your switch box isn't isolating the signal between your components very well. ????
  3. schmeegle
    schmeegle
    Would it be between the components, even tho it's a ghost of the DVD image, if you see what I mean? Also, last night I tried just my DVD player to switch box to TV, with no other components, the ghosting was still there :eek:
    The site I bought it from has said they would take it back & exchange, but is there anything I can do to avoid that hassle?
    Thanks for the help
