interferance on projector screen from all sources
Discussion in 'Home Cinema Buying & Building' started by paulcharlier, Mar 11, 2006.
  1. paulcharlier
    paulcharlier
    Hi there,
    before I start I hoping this is the place to be with questions about AV :)
    Okay right, first off I'll describe the setup we have:
    Toshiba 3377DB Television
    Panasonic NV-SV121EB S-VHS Video recorder
    Sony VTX-S760U Digital TV Box (Sky)
    Toshiba DVD SD-500E
    Goodmans GHC56 Pro Audio Amplifier
    Acer PD-116 DLP Projector
    Okay the setup is as follows:
    Toshiba TV + Sony Digital Box are plugged into Panasonic VCR for output to projector.
    DVD player is setup for connection to projector.
    To enable switching between the two sources we have a AV switcher box, I am not sure of
    the make, but we purchase it from Maplins with a model number L63AB Audio/Video Source
    Selector. From the AV switcher it connects directly up to the projector.
    In terms of cabling, we have an S-video output from the VCR to provide picture on the
    projector for Analogue TV, Digital TV and normal VHS tapes. The DVD player also has an
    S-video output to the AV switcher, from there it connects up to the projector.
    Okay now the problem, when viewing ALL the sources on the projector we get a strange
    kind of interferance on the picture, the best way I can describe it is that it has
    diagonal converging lines, which seem to dissapear when there is pure white, but with
    any other colour the lines are apparent.
    When trying to remedy the situation we connected the VCR directly up to the projector
    with a Composite video cable, this still did not remedy the problem. So from what I can
    tell is that the problem lies where all the equipment is installed.
    But to help desribe the symptoms and problem better I have recorded a small video
    showing the lines, you can download it from here:
    www.paulcharlier.com/interferance.mpg
    The file is approximately 10mb.
    Also I have taken a few photos of the setup, the locations and hopefully give an
    impression of the lengths of cable used.
    www.paulcharlier.com/projector/1.jpg
    www.paulcharlier.com/projector/2.jpg
    www.paulcharlier.com/projector/3.jpg
    I hope this is enough information about the setup we have,
    thanks in advance for any help given, I really hope we can find an answer to our problems,
    thanks,
    Paul :)
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Well, this is not going to be the source of your problem, but your equipment has way too little ventilation ! Don't be surprised if your boxes don't die within the year.
    I couldn't get the video to work, but what happens when you take the VCR completely out of the equation ?
  3. paulcharlier
    paulcharlier
    Hi mate,
    when you can say you couldn't get the video to work, what error is thrown up?
    is it error 404?
    I have just check it and all seems to be fine and working for me,
    cheers,
    Paul
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Just clicked on it again - worked this time. Looks like one of two possibilities to me - patterning due to poor quality cable, or maybe something happening in the projector, in the scaling process. Try connecting a DVD player directly to the pj, both with your existing s-vid cable, and with a shorter cable (you'll have to move the dvd player to do this).
  5. paulcharlier
    paulcharlier
    Hi Nick,
    forgot to mention it earlier, we have also connected the dvd player using a short and quality S-video cable directly from the DVD player to the projector.
    Its strange though, when looking at the picture on the television, there is no interferance,
    at present I am not really sure of what to do to improve the situation :rolleyes:
    Paul
