Interconnects
Discussion in 'Plasma TVs' started by Elvis, Sep 23, 2003.
  1. Elvis
    Elvis
    What kind of cables would people suggest for connecting a Sky+ STB to the media box on a Hitachi 42pd3000 Plasma.
    What are other people using in their set-ups?
    Is a high quality cable going to make much difference bearing in mind the variable source quality from a sky digibox, how good is the picture going to look on a 42" screen?
  2. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I'm using a fully shielded QED scart cable for my connection. Probably over the top but, when I had my last TV, it did stop a problem I had with a ghost image of terrestrial TV appearing when watching Sky. Picture quality (at least with the higher bandwidth channels) is excellent.
    John
  3. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    use best you can afford. it will be one possible problem out of the loop.
    ps long live the King
  4. Elvis
    Elvis
    Have you connected your Sky STB to the media box with a fully wired scart or video only scart (and if so how do you get audio to the plasma)?
    I've been looking at Ixos 801 or 611 leads as possible interconnects.
  5. jaminho
    jaminho
    Interested in this one myself.
    I'm doing exactly the same connections plus dvd
    Plasma arrives on Thursday.
    Apparently the connection of choice for sky+ to the tuner box is RGB scart, but which one is best?
  6. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I don't use the plasma for audio at all, Sky+ box goes to the amp via optical cable.
    John
