Interconnects - best place to buy?
Discussion in 'Plasma TVs Forum' started by Fozz, Mar 12, 2005.
  1. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Hi.
    I will soon be a recipient of a new PW7B and I need to buy some decent cables to hook the DVD and Digital to it.
    I am looking for decent quality Component (RCA - RCA), RGB SCART - RGB SCART and Twin Phono to Phono cables.
    Can anyone recommend good quality brands?
    What about websites that sell em?
    Any info will be appreciated!
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    tvcables.co.uk, audiovisualonline.co.uk, lektropacks.co.uk all very good sites with ranges from cheap to expensive
  3. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Cheers for the prompt answer.
    Have a look at this link to see the back of my NTL reciever:
    http://www.pacemicro.com/corporate/products/prodinfo.asp?PID=DC220
    See that SPDIF Optical Out?
    I wish to connect that to a Home Theatre System that also has an optical Digital Audio in.
    Would this cable fit the bill:
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGD4000.html
    Or is it this one:
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGD5000.html
    The connector on the back of that NTL box has a little cover on it and when I remove that I see a little red light in there.
    If anyone can advise what type of cable I use for this I'd most appreciate it.
    Cheers!
  4. Tony 21
    Tony 21
    Feb 8, 2005
    109
    16
    London
    You need a Toslink optical cable to carry digital sound to your amp/reciever
  5. Miniholic
    Miniholic
    Apr 26, 2001
    3,060
    The Shire
    +399
    It's the second (Optical) cable that you need. The Co-axial cable is for an electrical connection which your box does not have (the socket for this looks like a normal phono type connector).
    Hope this helps,
    Ian
  6. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Thanks Miniholic and Tony21.
    I've ordered those cables from tvcables.co.uk.
    By the way, I am assuming that I should use the Digital Audio cable for my audio from the Digital box to my amp instead of simple twin phono to phono cables?
    In my head the digital connects should be better...but then I could well be wrong!
    I suppose I'll find out when I set it all up and hear how it sounds!
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    as tony says its the only way to digital surround to the amp....if you use the twin phonos it will give dolby surround sound but not dolby digital
