Interconnect/speaker cable help pls???
Discussion in 'Hi-Fi Stereo Systems & Separates' started by thfcwestlower, Sep 30, 2004.
  1. thfcwestlower
    thfcwestlower
    Sep 26, 2004
    184
    +11
    I have recently purchsed the Cyrus CD8 and Cyrus 8 Amp to partner my Quad 11L's. I am still using speaker cable and interconnects that I was using with a budget system previously.
    I find that my current set up lacks real tightness in bass, especially at lower volume levels and is a tad harsh at higher frequencies at loud voulmes.
    Could anyone please recommend an interconnect/speaker cable combo that would tighten the bass?
    Thanks in advance for any advice.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    You could try Chord or Kimber. Both have helped me infine tuning a system.
