Interconnect recommendation A65+/CD62T
Discussion in 'Arcam Owners' Forum' started by jamesf, Dec 15, 2003.
Tags:
  1. jamesf
    jamesf
    I've recently purchased an A65+ amp/CD62T CD player and a pair of Kef Q35 floorstanders (which I'm very happy with) and now want to replace my interconnect with something half decent instead of the bargain basement one i'm using at the moment.
    With such a bewildering number of cable manufacturers and types about I don't really know where to start, so any suggestions greatly appreciated. I have a budget of anything up to about £30-35...
    Regards,
    James Frost
  2. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Hi James,
    I would recommend Atlas Equator
    Regards
    John
  3. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I'd honestly suggest you check out the Kimber range at RA. I'm impressed with the PBJ, not sure if it's within budget though.
  4. bobbypunk
    bobbypunk
    VanDenHul The Bay £40 well worth an extra £5
    or if your budget is strict QED Qnect2 £30
