Interconnect Cable
Discussion in 'AV Receivers & Amplifiers' started by Maidenman, Jul 4, 2003.
  1. Maidenman
    Maidenman
    Sorry if this is the wrong place, I have been trying to find an interconnecting cable which connects my DVD/SACD player to my AV amp.(6 to 6) to play SACD. However I can only find a 1.5m down at the local retail outlets. Anyone know where I can find one of these, as I said has to be 5 metres and 1 cable (there are enough cables running across the room between tv and amp)
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,461
    United Kingdom
    +1,909
    Probably best to get the cables made up for you and then run them through some trunking or something.
    Try here for the cables www.scorpioncables.com
    All the best :)
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    If you are on a budget try Maplins, they do some for Cars that I believe go up to 10M.
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
  5. Maidenman
    Maidenman
    Thanks but I was hoping to get away with something cheaper than £60. But if that's all there is, the price we have to pay
