interconect
Discussion in 'Home Cinema Building DIY' started by stranger, Feb 27, 2002.
  1. stranger
    stranger
    I am using a half metre cable talk reference phono lead between my sony ns900 and my sony str-va receiver. would a dedicated co-ax. digital cable make much difference? thanks for any advice.
  2. stranger
    stranger
    sorry-should read str-va555es receiver.
  3. paiger
    paiger
    Depends what you want to do. Is your cable 5.1 or just stereo? If you are just using a stereo lead then obviously you are missing out on DD and DTS as well as SACD. I don't know if you amr has Auto Format Detect on the DVD channel but if you use a digital cable, this will decode it and play the sound out of the right channels. For the record, I have a digital coax to the DVD channel for movies and stereo phonos to the CD channel on the amp which is set to Analogue Direct. I prefer phonos for music but the digital has more punch for films. I'm using QED cables for both by the way.
    S
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Sounds like a job for an IXOS 105 wBt digital co-ax (£30). It will sound much better than the standard phono lead you are using.
  5. stranger
    stranger
    thanks guys. Retro took your advice but bought a qed p75 you were right its a good improvement, incidentaly I was using a cable talk reference cable not a cheap one.
