interactive on sky
Discussion in 'Sky Digital TV Forum' started by micks_address, Feb 8, 2002.
  1. micks_address
    micks_address
    Nov 29, 2001
    4,635
    83
    Dublin
    +234
    Hi folks,
    Quick question about interactive services on Sky. Sometime i loose interactive altogether for a day or so and then it comes back. That is - the red button does noting during matches etc and text won't work on sky sports channels. It usually sorts itself out after a day or so but it's annoying all the same. Box is silver pannasonic one.
    Anyone experience the same problem and is there any quick solution to it. Also sometimes when i go to view a premiership plus match it's encrypted even though i have the season ticket - have to call up sky to get it turned on. A pain.
    Any info appreciated,
    Mick
  2. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    Not the answer you want, but unplug the box from the mains and then plug it back in again.
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Actually I think 'Networkguy' does have the answer you are looking for - I often have the same trouble and when I phoned up the Sky technical line they just told me to switch it off, leave it for 90 seconds and the restart it. Very technical!!!:eek:
  4. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    We have reached a stage where most things these days are reliant on software.
    So far, I have a Sky box that needs a reboot every now and then, a TV that needs a reboot every week, all the computers in the house that need a reboot and even phones that sometimes need to go through the process.
    The best one yet however was when I was having trouble with the car. Took it into the shop, and what did they do to cure the problem? Reboot the engine management system (and it sorted it).
    I think is one of the down sides to living in the year 2002. Everything needs a reboot every now and then.
    I wonder if it will work on the wife :p
  5. micks_address
    micks_address
    Nov 29, 2001
    4,635
    83
    Dublin
    +234
    thanks for the help guys,
    Mick
    P.S anyone have any idea when sky wil launch sky plus in Ireland?
