Inter connect quality question
Discussion in 'Cables & Switches' started by BLACK_MAGIC, May 31, 2004.
  1. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    604
    manchester
    Quite simply is it worth having good quality interconnects between an av processor and amps.
    To behonest i can not tell much if any audiable difference between a £10 and a £300 interconnect between a cd player and pre amp so would the same as a general rule apply in the case with AV processors and amps?
