Intel Nuc over HDMI to Denon Receiver. Only get sound when TV is on.
Discussion in 'Home Entertainment Computers' started by mbro, Jun 14, 2015.
  1. mbro
    mbro
    Jan 1, 2014
    5
    Hoping for some assistance here. Have been happily using my Intel Nuc connected to a Denon AVR-X2000 Receiver via HDMI for the past year or so for Plex Home Theatre. Have started playing music via Plex and through Spotify on the Intel Nuc but have found that if i turn the TV off the sound stops playing shortly afterwards despite the Receiver and the NUC still being powered on. I would much prefer to be able to just have the Receiver and NUC powered up and have the music playing. I have been searching through the receiver options but cant see anything that would help here. Would anyone have some ideas of where to look?
    Thanks so much!
  2. mbro
    mbro
    Jan 1, 2014
    5
    Have narrowed the issue down to Viera Link. If i disable viera link on the TV then it doesnt seem to disable the sound when the tv is turned off. Unfortunately i have Netflix running through the app on the TV and passing the sound through the receiver and when i disable viera link it stops this from working. Thinking i may be stuck here with having to choose one or the other unless anyone else has an idea?
  3. Jamie
    Jamie
    Jun 27, 2007
    5,395
    2
    Harrogate
    +1,405
    A workaround might be possible by running an extra cable from the TV rather than using ARC.
  4. mbro
    mbro
    Jan 1, 2014
    5
    Hmm, nice idea. I will give it a go today and see if i can get it going. Cheers!
  5. Jamie
    Jamie
    Jun 27, 2007
    5,395
    2
    Harrogate
    +1,405
    I'd expect your TV to have an optical or coax audio output you could use.
  6. mbro
    mbro
    Jan 1, 2014
    5
    Looks like i was able to get it going. The opt out didnt work initially as i need to have Viera Link enabled to allow the Opt out to work. Once i was looking at though i discovered a sub menu to the Viera Link setup that let me have Viera Link enabled but have the option to power down connected devices set to disabled. I set it that way and now everything is working as i want. Thanks for the hlep Jamie as i probably wouldn't of looked further into the menus without the input.
    Ack, scratch that. It was playing away for 10 minutes but then stopped. Doing some further testing now.
