Quantcast
Intel 8i7BEH 8th Gen NUC + Akasa Plato X8 Fanless PC Build
fallinlight
I just access mine headless from my main gaming PC, laptop or work (or even smartphone) 99.99% of the time just using OpenVPN & RDS so normally no screen/keyboard/mouse use to it. Just used as a box for file storage & as media server using as little power as possible with it on 24/7. Can be sat untouched for months just doing its stuff with occasional updates & new files transferred to it.
Sorry, I don't fully understand what you said. I'm a simple, plug and play sort of person at heart. I know headless means no screen - had to look that one up the other day! But I gather you mean that you use your mini PC as a media server and file storage device.
Will longer antennas be better? I already have these,
https://www.amazon.co.uk/gp/product/B07FDN82D8/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
They look longer than these,
https://www.amazon.co.uk/gp/product/B07PG8RWDQ/ref=ox_sc_act_title_2?smid=A3F8F97TMOROPI&psc=1
I think I might as well get the above the set you linked me and I can compare both.
psikey
Antenna length is a space issue for me on my AV shelf (gap between shelves). Long ones would be better if you have the space as more away from the Aluminium casing.
Sorry, I just remote connect to my NUC using Windows Remote Desktop Service (built-in to Windows + also an app for phones/tablets). If accessing my NUC remotely I connect to my home router via OpenVPN for secure connection.
Only time I would hook-up attached screen/keyboard/mouse is if it became unresponsive & I had to trouble shoot it. I even have mine powered from a small UPS so can even operate for about 1hr if loose power to the house (protects media drives plus noise/surge protection).
fallinlight
OK, excellent, thank you. Think I will just go with the 10 cm pigtails (no antennas) and use my existing, longer 6 dBi antennas. I have enough space on my rack.
If assessing my NUC remote from home I connect to my home router via OpenVPN for secure connection.
That's pretty neat, forget about things like that.
Your set up sounds great, well done.
I go through obsessive phases, researching and sometimes trying such things out, but like I said, I'm quite a bare bones, plug and play guy, at heart. I have been focusing a lot of energy on my home cinema room at the moment, which is really taking shape.
Do you know of a good remote I can control my NUC to do the following?
Power on from cold
Power down
Sleep
Ideally, use as a remote for Cyberlink Power DVD and to navigate my desktop
I tried the official Xbox 360 remote on a whim, but it only turns it on and off, if I remember correctly.
psikey
Only smart remote I've ever used is a low-end Harmony (still have somewhere). Don't use a remote with my NUC's seeing as they're used only as a server, not as direct players.
I did have the Cyberlink remote a few years ago too for use with my QNAP.
Do you have a external USB BR drive connected to your NUC? I even have and external BR read/write USB drive (not connected & rarely use but useful to have).
Manged to get Scan to source me the Akasa Turing. Special order as not even on their system yet (or anybody else's that I've seen). ~ £115 with delivery expected 5-7 days. Great price considering the Plato not much cheaper at £99 yet Turing much more Aluminium.
May to a "build" thread when it arrives.
fallinlight
Cool. Is there something/ Harmony perhaps, that I can use to operate all of my devices (JVC X7900, UHD player, Yamaha amp etc?). Sick of so many remotes.
Nope. Used to have a drive in my old PC, though. Was scouting for a good external 4K ripper but can't find one, just that LG internal one. Can't be asked at the moment, just playing from disc.
Lovely. The Plato is unbelievably robust and strong. I've knocked it HARD with a plug and one other time with something, thinking - or not even thinking, I kind of knew it would be OK - that there would be at least a small dent, mark, scratch or chip. But nothing whatsoever. Pretty bloody good and a massive relief, considering I suffer severe OCD over things like this.
I look forward to reading it if you do.
fallinlight
Ah, yes, kind thanks, psikey, these are what I have seen other fellow AV enthusiasts link to and talk about.
Barney Gumble
Other things to note
You loose the NUCs SD card function, unless it is possible to mod the X8. I forget the location of the SD card chip, but perhaps there is a workaround. You also loose the microphone function, unless you purchase new wires that run the correct length for the X8s left and right microphone holes. These are either side at the face of the case. The mics would come in handy for me for the odd video call, but this will soon be in my AV rack at the back of my room.
I am not capable of undertaking this sort of thing so bravo.
I've read this with interest as I had Scan build this for me using the same NUC & X8 case.
However, I returned it complaining the dual mic array hadn't been connected. Scan sent a replacement & again, despite me asking them to check the mics prior to dispatch, sent out a replacement minus the dual array microphone set up.
Included with the case is the microphone extension wire to reach from the mother board to the front, only Scan have removed the microphones altogether & haven't sent them to me.
So, can i please ask; did you receive the micrphhone extension cable as part of the X8 case contents when purchased? If so, did you choose not to use it due to your intended purpose for the PC?
I'm inclined to return this yet again because I do wish to use the mics. What I will say is, the unit is absolutely silent other than this issue & exactly what I wanted from a new PC, silence.
fallinlight
Good morning, @Barney Gumble, I hope you are well.
No, the microphone extension lead was not included and as far as I am aware, according to the manual, is not meant to be included. Yes, that is correct, I chose not to use the microphone due to my intended purpose for my PC. To date, since my last post, everything has been 100% stable.
I am not hot on this stuff, and it is only the second PC I have built. I just taught myself with a bit of daring. That is all you need. Then the daring disappears really once you gain confidence.
Again, I would not worry. I don't think the manufacturer or supplier has messed you around - to my knowledge. I purchased mine from Quiet PC, and they were very good to deal with.
Best regards,
fallinlight
fallinlight
@psikey, I finally installed a Wi Fi antenna (bluetooth needs a lead longer than 10 cm). But after trying all combinations of the nut, washer and washer/ spacer lock (I think it is called), I cannot get the antenna to be sturdy. I have all fixings on the outer side, as pictured below. The antenna just flops around if I move my PC and I cannot turn it 360 degrees around without the nut etc and the wire instead rotating (it will of course coil up the more you spin it). Should I be able to rotate the antenna 360 degrees? Or, are they designed to just lift up and press down flat - that is natural and easy to do to it. The ridged end part of the antenna is very tight and does not really rotate unless you force it.
I have turned by hand, the nut as tight as I can. It tightens and feels tight. But after screwing in the antenna and any attempt to rotate the antenna left/ right, the fixings and antenna becomes loose. I looked at my Yamaha A3070 AVRs antenna, which is solid, in place.
Here is a photo:
psikey
Which ones did you buy? My £7.99 antennae/cables arrived but not fitted mine yet. May fit mine this evening (or Saturday latest).
Add a photo showing a wider view. Just looking at your photo above I'd normally have the spring washer teeth against the case.
Will post a photo of mine & comment once done.
psikey
Fitted mine all solid, some photos (don't look exactly same as yours)
The gold threaded length has a flat to line up with the flat in the casing holes.
I used the spilt washer on the inside and star washer on the outside and tightened with spanner (i.e. washer on each side touching case). Looks like you have both star & split washer on outside.
Bottom photo shows WiFi signal max strength connected at full speed (866mpbs), NUC upstairs & my ASUS router downstairs.
fallinlight
Hello, @psikey, I finally installed it as you did and tightened it but used a pliers as I had no spanners that fit. It is much tighter and more secure than before. Many thanks.
akerblad
To lower the blue LED brigthness I found this instruction very helpful:
I set mine to 5% which really helped.
Trending threads
