Question Integrating AVR with HiFi
Discussion in 'AV Receivers & Amplifiers' started by suixt, Apr 4, 2016.
  1. suixt
    suixt
    Jun 7, 2015
    12
    4
    London
    I have a Marantz 6010 AVR and I'd like to connect that to my Hi-Fi system that features HT Bypass.
    At the moment I have 2 LS50 and a sub connected to the audio amp and I' m ultimately looking for a 7.1.2 setup on the AVR, which means I need to get 7 speakers more - 2 of them being Atmos enabled.
    Have a lot of questions, but I think the below ones address the most critical issues. Feel free though to point me the right direction if you think I am misinterpreting or forgetting something.
    1. What would be the optimal route to add the KEFs back to the AVR so that I take full advantage of the extra power/quality? (as front L+R?)
    2. Is it possible to have the sub connected all the time to both the AVR and the audio system?
    3. Is there a speaker configuration that is considered optimal compared to the rest for the 7.1.2 set-up? I was thinking of going with C, FL+FR, SL+SR, SBL+SBR, DFL+FDR
    -pic of configuration:
    http://manuals.marantz.com/SR6010/NA/EN/fig/Pict SP Layout 9.1 FD_DRDZILqtibciod.png
  2. floyd droid62
    floyd droid62
    Sep 17, 2016
    257
    shrewsbury
    +26
    :confused::confused:
    not sure if this helps but i would connect everything to avr, than use pre out to your hifi for the L&R speakers,taking advantage of the ht by pass but i am only a novice.
  3. floyd droid62
    floyd droid62
    Sep 17, 2016
    257
    shrewsbury
    +26
  4. floyd droid62
    floyd droid62
    Sep 17, 2016
    257
    shrewsbury
    +26
    Went wrong somewhere ignore confused confused sorry about that
  5. High Fidelity
    High Fidelity
    Sep 1, 2007
    954
    64
    +271
    Correct
  6. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,624
    London
    +722
    I beg to differ.
    If looking for improved music qualty, then:
    1) Use AV pre outs to HT bypass inputs on amp. Connect front L/ R speakers to stereo amp and center, sub and rears to AVR. Connect music sources to stereo amp and video sources to AVR.
    2) Yes but depends on sub. If it has High and low level inputs then you are good to go. If not then maybe a A/B switch between the amps and sub could do the trick.
    3) Looks about right if that's how your layout is.
    What stereo amp do you have?
    The Marantz AV is pretty decent with music tho not as good as comparable priced stereo amps.
