Integrating a home cinema with Clark Synthesis transducer
Discussion in 'AV Receivers & Amplifiers' started by JohnBurnett, Feb 19, 2016.
  1. JohnBurnett
    JohnBurnett
    Feb 19, 2016
    Croydon
    Good evening everyone,
    Be gentle, first time poster here!
    I am buying home theater seating from a company in Kent that also supply Clark Synthesis tactile transducers to go with the seating.
    However when I was speaking with the lady I asked the question of what is needed to power the transducers and she said that I need an amp but was unsure on whether my amp would suffice as the sub is not powered.
    I am using an LG 5.1 system that uses propriety connections for the speakers (could be spliced if needed) left and right in (analogue) usb, 1 x hdmi out and 2 X hdmi in.
    I am hoping to use this with TV, Sky HD box, Xbox One and an Andoid box.
    Does anyone have an suggestions on how this can be configured using my existing hardware?
    I would ideally like to have the transducers react to the bass frequency as opposed to left and right as this is how they are meant to be used.
    I would also if possible like to use two or four transducers if possible.
    Any information / advice would be much appreciated.
    Many thanks,
    John
