Integrated Stereo Amplifiers with DACs?
Falp
I bought my first Surround Receiver partially for digital inputs.
With aren't there much Integrated Stereo Amplifiers with DACs?:thumbsdow
I'm thinking of upgrading, keep DVD player, need 3 or 4 digital inputs, and not much in the market if I stick to Stereo, new and on a bugdet...:mad:
The ones I found:
Advance Acoustics MAP305DA (Maybe my future amp)
http://www.advance-acoustic.com/en-product.php?id=25
Music Hall Mambo/Maven:
http://www.musichallaudio.com/mmf_products.asp?show=false
Lyngdorf Millenium/TDA220 (€€€€...):
http://www.lyngdorf.com/ContentId/353/Default.aspx?MenuItemId=33
Shanling SLM-A40MKII
http://www.shanling.com/SLM-A40MKII.htm
Bryston B60/B100 + DAC option
http://www.bryston.ca/dac_m.html
Only this on the whole internet? :eek: :rolleyes:
Manufacturers...:lease:
Knyght_byte
to be honest i think having DACS in a stereo amp is broaching the purity side of things....
a surround amp needs them for the obvious reasons that most people only want a one box AV product....
but a stereo amp, to my mind, if you have to go integrated should be a dual mono design, no tone controls or balance......just input switching and volume, perhaps a built in phono i guess for sake of ease....
but the DACs should be left elsewhere.....DACs can use a surprising amount of juice if they are powerful enough so taking that from the PSU would cause fluctuations (far as i know) that would degrade the amplifying ability....
obviously the simple answer is to buy a offboard DAC if you want to plug multiple digi connections in to it.....plenty of options exist.....you gets what you pay for obviously...heh
i think generally you will only find DACs in the amp when a drive is present as well......ie Linn Classik etc.....some of these might have optical/coax inputs as well....(dont know for sure if the Classik does, i just used that as an example of DACs being onboard)
Falp
I cannot agree...
Lots of people buying outboard DACs for DVD Players as transport, Audio streming, setup boxes... it's a product missing specially with many people going back to stereo...:cool:
Falp
