integrated freeview tv
Discussion in 'Freeview & YouView' started by vespaman71, Oct 8, 2004.
  1. vespaman71
    vespaman71
    hi ive just purchased a sony freeview tv but really wanted a top up tv can i upgrade to top up tv without buying a box.my tv has no card slot. :confused:
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    You will need a CAM an old Ondigital one may work - check with Sony - cards currently are a problem - you can only use official ones.
    A new SECA2 CAM is about £50
  3. vespaman71
    vespaman71
    sorry im a bit thick whats a cam and where does it go
  4. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
    Your TV should have a CI (Common Interface) slot somewhere on the back. You can buy a Top Up TV (Conditional Access Module) for about £40 to plug into the CI slot. Then you put your Top-Up card into the CAM and away you go. It's best to check at www.topuptv.com that your set is compatible before you buy the CAM. Their site also has more detailed information on how it all works.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Please note that TUTV is only 4 1/2 channels (basically half of SDN) so you get bits here and there.
    Also CAM is quite pricey and you have to pay an extra £20 for the connection, if you lapse a couple of months you have to pay another £20 to get reconnected.
    It is expensive and limited compared to Ondigital, to be honest I would be surprised if it lasted a whole year.
  6. vespaman71
    vespaman71
    thanx anyway
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Sky have an offer £150 no monthly subs and contains most of the channels TOPUPTV give IIRC
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    One thing I will mention just about the best digital TV picture you will get is from a Sony IDTV running on its own tuner.
    TUTV would be cheaper than sky to get but it is limited, however there are some gems on Freeview.
    ABC1 is great - OK I like Moonlighting
    UK History is good - OK I like war machines (eg anything Merlin powered)
    And the 2 music channels are good
    AVFORUMS voted for Freeview - we did a poll which I reckon accounted for a large percentage of replies for ITC.
