you actually want the amp to be able to overpower the speakers...that way you know the amp isnt underpowering them....thats when most problems happen.....you can always keep the volume control down with a powerful amp.....with a weak amp, running it up full is more likely to damage something or lots of things...lol
my GR10's are 100watt power handling, my A5 is 250wpc
my S6's are either 150 or 175watt power handling and the A5 powers them once in a while too....
the best bit with an amp in the league of the A3.5 (or similar by other manufacturer) is that it will most likely survive your next speaker upgrade.....so its a case of economics.....get the cheaper amp now, but when it comes to upgrading speakers you might need to upgrade the amp as well....however get the best possible amp you can stretch to now and you shouldnt need to replace it when you up the speakers......thats why i bought the A5, essentially a A3.5 would have done me fine, but i know i want to upgrade at some point but without doing all components at once...so i get the A5 and can happily power most speakers worth up to around £4k with it.....might need to add a power amp with some, but hey, they do a matching A5 power amp....heh....
whether you buy MF, Arcam, Densen, Primare, Naim, etc, either go for something around £400 or go for something around £1-1.2k........the cheaper amp means you wont feel so bad upgrading to a new amp...the more expensive amp means you wont have to......buy something for £750 now and you'll be betwixt and between.....
just the way i look at it anyhow......always best to go with what feels right to you.....no point making me feel happy, its your ears
