Integrated Amplifier or Stereo Preamp for KRK Monitor Speakers
coleccionistadl
Hi guys,
I got a pair of monitor speakers KRK (RP5-G4). I connected it to a Bluray player (Oppo 203) to play flac, cds (SACD, WAV) stereo, I use an XLR to RCA converted cable for the connection. However, I found that the quality is not good enough. How can I improve it?. A friend told me that I must buy a DAC Topping with XLR Output and RCA input for my Bluray Player. Some suggestions, please
(My budget to improve my system is $600)
Khazul
What specifically is wrong with the sound?
Also, what size of room, what is your listening distance? With those monitors these things can have a vastly more serious impact than the subtleties of one decent DAC vs another.
The Oppo 203 has a perfect good DAC in it. You shouldnt get a sound change (except maybe level) in adapting RCA to XLR unless something is seriously wrong with the cable and/or adapter.
If you bought the monitors recently, it could well be you simply dont like the somewhat in-yr-face sound from many KRK monitors.
I still have a pair of mid range KRK monitors (+sub) from a decade or more ago - they are great for audio mix work (where their in-your-face presentation is useful), but can be a bit intense at near field distance to simply listen to music and can get a bit lost in a large room when several meters away from them.
Paul7777x
Have you made sure you’ve set the Oppo to downmix to stereo output from the left and right analogue outputs?
coleccionistadl
It was a problem of configuration, now is working. By the way, I realized that there is a slight sound (like a motor) when I set high volume in the KRK. I don't know how to explain that I tried to record a video, some noise :( . It is noticeable when I listening jazz
Paul7777x
I’d not use anything further than half way on the KRKs volume pot. Possibly not even that high.
You’ll get a quieter background by using the preamp in the Oppo close to its max; set it at around 75%.
Then set the volume on the 5s to where it is just too loud for normal listening and back it off a bit until it’s about right, then use the Oppo for increasing and decreasing the volume thereafter.
coleccionistadl
I make this short video (Attached). If you can listen every 4 seconds there is a noise. How can I avoid it? The sound in the KRK is set to 0db, and the Oppo is 35
This is the video link of the noise:
Ugg10
Does it doe it without anything attached to the speakers. If it does, try plugging the speaker into a different power socket, maybe upstairs or at least in another room. This will tell you if it is a mains loop issues e.g. a fridge or or their appliance interfering, or it is internal to the speaker or in the source.
coleccionistadl
It happens only when I turn on the Oppo player (the noise comes through the analog cables). I tried it in another outlet same noise. Also I tried with other speakers (PreSonus) and other analog cables same issue.
Paul7777x
That is a bizarre sound.
Have you made sure that the mains lead from the Oppo is secure, that is all the contacts, especially earth (ground), are clean and tight?
Bit desperate I know...
Following that a mains filter/suppressor is all I can suggest.
One for the fridge, any electrical heater, cooker... anything that may inject noise into the system.
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
