Integrated Amp Suggestions
Bails
I am wondering what integrated amp with av pass through I should get.
I have a Marantz sr-9300 receiver but would like to add a separate two channel amp to get top-notch stereo sound (not that the Marantz is any slouch).
I know Arcam produces some fine amps. Would they provide an improvement over the Marantz? What about Krell? SimAudio? Any other suggestions?
Also, to what extent do the amps in the integrated amp need to sound similar to those in the receiver? For multichannel music and movies, in particular, I imagine the amps need to be similar.
Any advice would be gratefully received.
N
nthornhill
You do indeed need similar sound to ensure that the surround soundfield for multichannel stuff remains matched.
For this reason, the logical place to start looking would be the various Marantz monoblocks which you can add onto the pre-outs of your SR9300 front channels. However, you then remain using the preamp section of the SR9300 for all music, which is not your intention.
Of course, the issue depends a lot on what your speakers and source are : There is little point in spending a lot of effort matching all amplification channels if you don't have identical speakers on all channels, of course.
Podcast: LG C1 Review, Apple Lossless & Dolby Atmos @ no cost, Sennheiser IE900 review + more
