Intego Problem
henryv
Established Member
I removed Intego from my Mac Catalina 10.15.6.
However one file keeps coming back!
The file is Intego - extensions - NetBarrierMonitor-NetbarrierNetwork-NetbarrierProcess.
I move it into my Bin and delete, but it comes back!!
Any advice will be greatly appreciated.
MacrosTheBlack
Looks like they recommend using the Installer to complete the uninstall. So you might need to reinstall it and then run the installer again and follow prompts to remove.
Let us know if that solves it.
MacrosTheBlack
Additionally I would recommend rebooting your Mac after reinstalling. Then after the reboot run the install again to remove it. Before rebooting again to check for any files left.
Sometimes though programs do leave bits behind. I wouldn’t be overly worried.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
