insulation
Discussion in 'Home Cinema Building DIY' started by go5, May 24, 2003.
  1. go5
    go5
    is sound insulation in an enclosure neccassary? What thickness and how much do you use? What are the pro's in doing it?
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,015
    What do you mean by 'enclosure'? A room or something else?
    Gary.
  3. go5
    go5
    speaker (subwoofer) enclosure
  4. Peter O Sullivan
    Peter O Sullivan
    It is fibrefill that they put in to enclosures. Roughly the same as insulation. The main point for using it is to increase the acoustic volume of the enclosure so that the enclosure doesn't have to be massive (relatively speaking of course). For example, a 150litre enclosure stuffed with fibrefill will simulate about 180litres of volume. Usually a max increase of about 25% can be acheived.
  5. shodan
    shodan
    Dec 11, 2001
    10,115
    shoeburyness
    +4,400
    I would've thought that putting that stuff in would reduce the amount of "free" space in the enclosure... Just shows how much I don't know!!!
  6. go5
    go5
    okay, so the question is, to insulate or not to insulate....
    my box is 1.82^3(ported). that is what I wanted it to be. So I should not stuff it than? If I do the volume increases, that is not what I want right? What about the advantages it gives like absorbing higher frequencies, do I want it for that?
    Some people say do , some don't.
    I guess there is no for sure answer
    Thanks for all help
