Insulating interconnects
Discussion in 'Cables & Switches' started by deaf cat, Nov 4, 2005.
  1. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Hiya,
    Have been trying Nordost interconnects between pre and power but seem to get a hummmmm only when the Nordosts are pluged in.
    Nordost suggested wrapping the cable in tin foil, but for some reason the hummm got louder?? :confused:
    Any ideas, I have plenty of plumbing PTFE tape :rolleyes: but as the cables are borrowed I am a bit worried in winding loadsa PTFE tape around them and then spending hours and hours trying to get the tape back off. :rolleyes:
    Look forward to hearing any thoughts.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Sounds like a ground loop - can you remove the shield from one connector of each cable?
    Actually first I would try another (cheap) pair of cables - if it still hums disconnect the shield as stated above. At least that way you won't damage the expensive cables if it doesn't work ...
