Instructions wanted for ASDA Durabrand ledvd 0701
canlabmaster
I can't find any on-line providers of the instructions for this little DVD player from ASDA. Would anyone reading this be prepared to scan and e-mail me the important bits to help with the slightly more advanced functions - setting up is easy enough? I'd be most grateful.
Andy98765
The need for instructions on setting up a DVD player is not really needed.
If you Scart out only then you have a few options.
Lets assume you have a widescreen TV with a Scart socket that is RGB enabled.
Set the output to RGB not Composite.
Set to 16:9 not 4:3 or some letterbox mode.
If you want to connect to a AV amp via optical or digital co-ax then the only sound setting is to enable bitstream out.
Can not think of anything else of importance.
canlabmaster
Thanks Andy98765. You're right of course, but I want the instructions to be available as reference for a person who is a bit non-technical.
