G
gifford
Hello fellow enthusiasts:
I would grateful for some advice and if possible a web pointer or e-mail for instructions on the various butons on the Seleco service remote RC3000. I acquired one of these for my Seleco SVP350 so that I can do some touchup convergence and tweaking.
Additionally, would someone advise how difficult is it to setup the projector as I will have to move it to another room and will be using a larger screen. Ideally I would like to set the banks up for constant height variable width viewing.
I do not have access to a technician to set up where I live (300km from the nearest major city) and the company who set up initially went out of business.
The manual isnt all that clear on some issues, so I would need to obtain advice on what order I do things in. I have all the original shims , the projector is set for 100" diagonal screen, and will be reset for a 16:9 2.7m width by 1.5m high matte screen.
Also (sorry for this long post) would the projector benefit from using RGB rather than s-video (in which case I will need to get a compenent to RGB signal converter? as the DVD has component)
cheers, this board has a wealth of info and talented people
bill
bill
