Instant On - Suspended Game Resume and Dash Issues
Det
I'm tired of logging back on after a hard day's work and wanting to load up Titanfall to have it lock up after 5 seconds and me have to reboot it.
I can't be the only one suffering from this. Happens nearly every time.
Also tired of the side stuff on the home screen having the forever loading circle icon and then the inevitable "We're sorry" bit.
Does the next update fix these issues?
mudshark
Would load my pins at all yesterday, just got the "sorry" message.
nstokes
Ive had that loads and found a hard reset will fix that
Det
Had a hard reset and it didnt do the trick with me yesterday. Frustrating.
RenaultSport
Never had that with the pins, There was an issue with one of the BT Homehubs causing a similar issue.
turk3y
The issue I get is a sign in has changed and it logs you out of everything, I am the only user of the console so not sure what's happening.
Also for games like tf you will get kicked to main main game screen as past there your connected to servers which you would have been kicked from for being idle when you turned off.
Otherwise the resume has been fairly good but not higher than 90% success I suppose. Better than a kick in the knackers I suppose. ;)
Lostsoul 301281
Pardon?
I think I get what you were trying to say, which is that if you try to resume games such as Titanfall you will be kicked from the severs for idling.
I've had that, and I've had an issue with loss of sound when trying to resume Tomb Raider.
I'd have to press the menu button and select quit, the reboot the game.
turk3y
Pardon?
yes probably not the best at explaining,
in Titanfall when you get to the main menu the first thing the game does is connect to back end servers that feed all the menu items so even tho you have still not said what type of game you are playing I believe you are "connected" to a server. Idling here will get you disconnected and dumped back at the main holding screen, I assume resuming will cause issues as the server slot you had will probably not be valid at resume time and so cannot really resume only take you back to the first menu screen.
this was more an excuse for titanfall due to how it works, BF4 seems pretty bad for random glitches, sometimes the resume fails and I am unable to load again after quitting for 30 seconds or more. There is certainly some bugs left in the resume code but when it works its pretty cool.
