Instant Budget Projector Screen
utter
Apologies if this idea isn't original, but I notice that the reverse side of my 70” wide canvas roller blind is white vinyl. It's also very thick and obviously, by it's nature as a blind, will hang flat. I reckon it would comfortably accommodate an 80 inch diagonal projection at 16:9 ratio. I think the blind cost £20 from a well known DIY outlet.
andyr300
Should do the trick, only issue will be marking out the white part and finding something to stick on to be the 'black part' around the edge.
utter
Several runs of black insulating tape, maybe. Hardly perfect, but less trouble than painting a sheet of mdf and better than projecting onto a wall.
