installing word
Discussion in 'PC Gaming & Rigs' started by chilpillphil, Jan 14, 2004.
  1. chilpillphil
    chilpillphil
    i installed my mates copy of office xp, it says i need to register it, or it will stop working, what should i do?
    can i download a key gen?
  2. HMHB
    HMHB
    Nov 11, 2001
    26,451
    Nottinghamshire
    +5,071
    what you need to do is to buy a copy for yourself.
    The product will only work for a short time if it is not registered, and it won't let you re-register it for a different computer
  3. chilpillphil
    chilpillphil
    crap, it costs loads, is there any reason to upgrade from office 97 or not?
  4. HMHB
    HMHB
    Nov 11, 2001
    26,451
    Nottinghamshire
    +5,071
    Probably not to be honest - it depends what you want to use it for really. A lot of our customers are still using Office 97 with no problems.
  5. Azrikam
    Azrikam
    I don't see any difference between Office 2000 and Office XP. And only minimal difference with Office 97. Unless you're into using all the bells and whistles, you should be fine with 97. Personally, I use OpenOffice now. :D
  6. chilpillphil
    chilpillphil
    ok, well i got a crack, its working fine now
    no difference lol
  7. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    ok but dont mention it again. It IS illegal you know.......:rolleyes:
  8. chilpillphil
    chilpillphil
    yes, thanks for all your help though
