Installing Windows onto SSD
Discussion in 'Desktop & Laptop Computers Forum' started by trogg1963, Apr 1, 2016.
Tags:
  1. trogg1963
    trogg1963
    Jun 14, 2010
    29
    Hi.
    I'm picking up my new computer tomorrow and I'm looking at buying a ssd to go with it.
    My question is, how will I move windows to the new drive ?
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,607
    Norfolk
    +2,463
    You can get cloning/disk image software for moving an OS install between disks.
    Although if it's just a generic computer with no special software or setup on it then I'd consider downloading the Windows 10 installer from Microsoft's website and starting completely fresh:
    Windows 10
  3. trogg1963
    trogg1963
    Jun 14, 2010
    29
    You make it sound nice and easy, do I replace the original drive with the new ssd and use the original drive as storage ?
    Thanks for the link :)
  4. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,607
    Norfolk
    +2,463
    Well, the best idea is to stuff as much as you can on the SSD. If you can't afford a big enough SSD for everything then put the files that have least use and least benefit from an SSD on another drive.
    So you'd be 'replacing' in it usage terms. I wouldn't physically replace it unless your new computer doesn't offer you any other option.
