Installing Terminal boards
Discussion in 'Plasma TVs Forum' started by ReHaBWales, Sep 12, 2004.
  1. ReHaBWales
    ReHaBWales
    Jan 7, 2003
    112
    16
    I'm about to install the terminal board into my Panny 6. The instructions say to lay the plasma down flat to do this but I've read somewhere that you should never do this...is it just a myth or do plasma need to be kept upright and if they do is there a safer way to install the board?
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Just make sure your tools are not underneath. You have heard another plasma myth, not quite as funny as re-gassing, but the manual is correct, a soft rug is good for this, stops the bezel getting scratched.
  3. ReHaBWales
    ReHaBWales
    Jan 7, 2003
    112
    16
    Thanks MAW. I thought that was the case but I had to be sure. :)
