Installing Sky+
Discussion in 'Sky Digital TV Forum' started by Monkey Alan, Mar 7, 2005.
  1. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    Is it possible to install sky+ without me drilling another hole in the wall an getting a new lnb?
    Is there something wrong with just spliting the signal after it comes through the wall?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    If the existing hole is big enough then inserting two cables or a shotgun cable is possible. SKY+ uses two tuners so requires two independent inputs to make full use of it's abilities so the cheapest option is to fit a twin or quad LNB.
    Since SKY+ uses two tuners and both of those tuners communicate with a LNB by sending a tone/voltage then you can see why a single cable carrying two sets of commands to a single LNB would cause problems as it requires those commands to switch between Horizontal and Vertical polarities and High/Low bands.
    One tuner asks for one setting and the other another so at anyone time it's possible to have no access to half the channels that you are payign for.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +324
    Alan,
    Yes, you need an LNB with at least 2 outputs. Quad LNB's are routinely supplied with Sky+ systems. You can't 'split' the signal.
    CT63 'shotgun' cable will fit through the existing hole in the wall. You won't get another standard cable through unless the hole is bigger than Jordan's. :D
    A. Dork
  4. kennysatman
    kennysatman
    Mar 3, 2005
  5. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    628
    +39
    Cheers guys that info really helped me.
    What I'm getting so far is
    1 skyware quad lnb
    8m of CT63 cable, 4 F connectors
    So I think all I need now is the sky plus box it self. Whats the best one to get? And where from?
    :thumbsup:
