Installing Sky+ myself?
Discussion in 'Sky Digital TV Forum' started by irvspeed, Dec 16, 2003.
  1. irvspeed
    irvspeed
    Dec 2, 2003
    41
    If I want to install Sky+ myself what is involved? I will be upgrading from a normal digibox so dish is aligned etc. Do I have to go into the install menu & if so remind me to get in & what to change or set etc. Thanks.
  2. shawkins002
    shawkins002
    Dec 12, 2002
    237
    Epsom, Surrey
    Sky+ uses two tuners, so you need to install a quad LNB on the dish - this has four outputs, as opposed to the one on a normal sky LNB. Then you need to run another satellite cable from the LNB in to the box, along with your current run. That's the tricky bit - also, installing the LNB itself may misalign the dish, as they are generally heavier.
    Once you have the two runs from the dish to the box, you will need to enter the installer menu (services 4-0-1 select) and do a new install. You will also need to ring up sky to activate the Sky+ features.
    All a bit of a pain - easier to get Sky round, unless you know what you're doing.
    Simon
  3. irvspeed
    irvspeed
    Dec 2, 2003
    41
    Thanks Simon, it was the new install bit I was wondering about.
    is it all automatic or is there info to enter?
    David
  4. kblue
    kblue
    I installed my Sky+ myself and it was very easy - quad LNB slotted onto the dish in place of the old one, and ran an extra run of cable.
    Didn't need to go into the installer menu - just plugged everything in and called sky to activate the box.
    Much better than going to the hassle of getting an 'engineer' around to do it...
  5. Line_Man
    Line_Man
    Dec 17, 2003
    46
    And you also dont have dirty marks on newly painted walls :(
  6. gbmitie
    gbmitie
    Apr 25, 2001
    1,139
    49
    republic of ireland now
    +61
    did u have to have tel line plugged in?
    gbmitie
  7. kblue
    kblue
    To get the viewing card activated, I think you need to have the box plugged into the phone line- at least I noticed the on-line light come on after I had called to activate.
    As soon as that was done, though I've never had it plugged in again!
