installing new ram memory
Discussion in 'Computer Components' started by PaulaB, Nov 4, 2004.
  1. PaulaB
    PaulaB
    Mar 6, 2002
    242
    Northamptonshire
    I have a new memory stick for my computer, is there anything I need to do to the bios to help install it? When I put it in it stuck on booting up and I don't know why.
  2. mjn
    mjn
    May 24, 2001
    22,246
    Herts, England
    +10,093
    Nope, the motherboard should auto detect the new memory.
    But things to check:
    Do you have to install the memory in pairs?
    Is it the correct type of memory?
    Is the new memory, the same / config as the existig memory?
  3. HMHB
    HMHB
    Nov 11, 2001
    26,857
    Nottinghamshire
    +5,637
    If you have a look on the Crucial site you can find out what's the best memory for your board. You can also download a tool from there so that you can identify what you hardware is.
  4. mi_july
    mi_july
    Is your ram running at the same speed ie. pc2100, or pc3200, if the ram is rated lower than all the others it should still work, however all the ram modules will drop to the speed of the slowest unit, kind of like the weekest link. Your system wont post (power on self test) and this is generally a sign of a poor ram unit or a dead one, i would RMA it, or you may find it will give you a BSOD later on.
    Alex
