Looking for some help in cabling up for TV/Video. I want to do this once and not need to change it in the future as at the moment it can all be concealed under plaster and under floorboards. At least that is the plan.
Currently installing: Loft mounted digital TV aerial and FM aerial both feeding a loft mounted 8-way amplifier diplexer. CT 100 cabling to each TV point, one in each bedroom and three in lounge.
Digital cable TV comes into the house in the hall from where it can be joined to one or more cables feeding sockets in the lounge. No plans to run this to the bedrooms.
At the moment I have no plans for satellite but would like to make provisions for cabling it since once the new floor is fitted I will not be able to make any changes.
A satellite dish would have to be installed at the rear of the house since this is south-east facing. I am contemplating running this around to the front where it could enter at the same point as the cable to allow be to route one or the other to the sockets in the lounge.
Is this a good plan? What is the total maximum length of cable that I should use, i.e. should I find a shorter route? An alternative may be to feed it into the diplexer/amp in the loft but at the loss of the normal aerial.
I have also just found out that Sky+ requires two aerial leads so what should I do about this? I am new to all this dont even have a telly at the moment.
Any help and advice gratefully received.
Andrew
Andrew
