Installing Freesat in Paris
kevismit
Hi, I am going to install Freesat in Paris shortly and have purchased Humax Foxsat HD (single channel), 80 cm dish, Quad LNB (for future expansion) and Konig sat-finder. As I understand it I must enter a UK post-code (to enable local channels) and either zone 1 or 2. As Paris is just about Zone 2, can entering a UK midlands post-code (zone 1) cause any conflict in the system? Or, do I need to set zone 2 and say a Scottish/Northern Ireland post-code? To test the equipment before departing France I assume I enter actual midlands post-code, Zone 1 and when finished do a factory reset, ready for Paris? Look forward to any replies. KSS :rolleyes:
PS what action in the Humax occurs when selecting either zone 1 or 2?
Vin Blanc
Set up your Humax at home using your West midland (I presume) post code and carry out auto-tune to get all the Freesat channels.
When you get to Paris, all you have to do is set up and aim the dish correctly, no need for any further tweaks to your receiver.
By the way, a 60cm dish would have been perfectly OK for Paris.
Vin Blanc
REPASSAC
80cm will just about do all over France (for the moment anyway).
Vin Blanc
Zone 1 and zone 2 are terms normally associated with $ky dish sizes.
Zone 1 – 44cm and Zone 2 – 60cm.
With all non $ky type dishes we normally just refer to them by size e.g. 80cm.
At present, to receive signals from Astra 1N ($ky and Freesat) a 40cm dish will work about as far south as Paris.
A 60cm dish will work almost down to about Avignon and in some cases even further.
An 80cm dish will get you almost to Barcelona on a good day.
Three years ago I managed to pull in all Freesat channels just north of the Millau viaduct with only a 37cm dish but that was very much the exception.
Of course, things may well change once we lose Astra 1N at the end of the year.
Vin Blanc
kevismit
Hi, thanks for the useful replies. Good idea to set up just once in UK. Reason for the 80 cm dish is that my daughter has close very high but not particularly dense foliage trees. However i notice a neighbour has a Sky type elliptical dish pointing thro' the trees at Astra, so it must work. So selecting Zone 1 or 2 in the Humax does what? does it vary the gain? KSS:rolleyes:
Vin Blanc
I have no idea what these two zones might refer to in a Humax receiver!
I have a Humax HDR but to the best of my knowledge the two zones that you mention only apply to $ky dishes.
Can anyone enlighten us?
I don't think the size of dish will do anything to improve your line of sight through the trees.
Vin Blanc
roland seal
" i notice a neighbour has a Sky type elliptical dish pointing thro' the trees at Astra," A lot of people imagine that the dish looks directly at the satellite but with the usual dist, which is called "offset" the dish is acting very like "in off the cushion" as played in billiards and such games. So when trees appear to be in the way the LNB which is located on the arm of the dish is looking much higher.
kevismit
Hi Roland, i appreciate what you say and i shall have a look. However these trees are about 50 ft high and about 40 ft from the proposed dish position. In my current location the data from Dishpointer.com shows Elevation 24.3, Azimuth 144.6 and Skew -13.3. How is the Azimuth calculated? If Astra is at 28.2 then 180- 28.2 = 157.8 which is not the same! So when i set up do i point at 28.2 from South or 144.6 from North? Am i being dum cos i realise Astras position is different for wherever you are and does Magnetic/Real North affect it? KSS :rolleyes:
logiciel
Use the "obstacle" option at dishpointer to find out exactly how high the trees can be.
kevismit
Hi, thanks everybody. Think for the moment have exhausted my questions. Will knock up a solid/sturdy frame tomorrow and give it a wizz. KSS :thumbsup:
REPASSAC
Remember to check both 28.2E and 28.5E Skew is a bit different.
Vin Blanc
If you are setting up with a compass then you need to use the "magnetic north" bearing.
28.2 East of south is the position at which Astra 1N is parked over the equator, not where you should aim your dish.
In regard to the trees and line of sight, see previous thread "No line of sight southeast" dated 25-07-2012. Thumbnail attachment in my post number 21.
Vin Blanc
grahamlthompson
There isn't a zone 1 or 2 setting on a Foxsat. The nearest I can think of is they have a high power setting for the lnb to enable use with very long coax connections. The post code you enter is merely used to provide the local programming regional variations for BBC1 at 101, BBC2 at 102, ITV1 at 103, ITV1-HD at 119 etc. Every postcode gets ITV1 London at 977 and all the BBC SD regions as well. Whatever postcode you use you can move any of the BBC regions to 101 and 102.
roland seal
"So when i set up do i point at 28.2 from South or 144.6 from North?" I believe the easiest way to do this set up is to point your compass to the south at mid(ish) day, you never know the sun might be there, and you will find the satellite 28.2 degrees to your left in the east. There is a magnetic consideration but trial and error will result in success. I live in northwest France, near Dinan, and use a 60inch dish with excellent results. Full deflection on both signal strength and quality. Good luck. Compared to installing a motorized dish it's a dream.
grahamlthompson
Enter your location in Satellite Finder / Dish Alignment Calculator with Google Maps | DishPointer.com and choose 28.2E. You get a google earth picture with the direction to the satellites plus settings for elevation and skew. Zoom in and drag the pointer to the dish location.
The satellites are above the equator at 28.2/28.5E. The compass bearing depends on your latitude and longitude. The further South you are the more easterly the compass bearing. If you were to go 0deg N, 28.2E the satelliite would be 22000 mls straight up.
kevismit
Thanks for all the useful comments. Found in the manual 9.1 item 4:- "9.1 Freesat Tune
1. PresstheMENUbutton. 2. Select Setup using the􏰀/􏰁button and press the
OK button. 3. Select Freesat Tune using the􏰀/􏰁button and
press the OK button. 4. Enter your region code. 5. Please note that once you perform Freesat Tune,
all freesat channels will be deleted. Select Yes and
press the OK button to delete all freesat channels. 6. Select Search and press the OK button to search
channels. 7. The channel search will start. 8. To stop the search, press the OK button during
channel search. 9. The results will appear. Select Save and press the OK button.
Note: If there are no channels available, a message indicating the result will pop up."
There is no mention of a Zone setting in the initial start-up procedure. KSS :thumbsup:
Stiggy
Do you really have to type $ky?
Can't we put that text in the swear filter to stop people using it? :)
grahamlthompson
The option is used to retune the freesat channel line up after you have correctly installed Freesat (Easy way to do this is simply do a factory reset and follow the on screen prompts). The manual tune option lets you add all free to air content to non-freesat mode wherever your dish is aligned on, unlike Freesat mode it ignores the UK postcode you supply.
Vin Blanc
Sorry you find my use of "$ky" so irritating Stiggy.
I promise I won’t use it ever again, – honest!
Perhaps in return you might try to encourage all those who inflict their bad grammar, bad spelling and/or lack of punctuation on the rest of us to try using the "spelling & grammar check" facility before posting, because that’s something that really irritates me.
Come to think of it, I think I know of someone living on a Greek island who sometimes feels the same way. :D :laugh:
Vin Blanc
Vin Blanc
grahamlthompson
Is that 22,000 miles above the eastern Congo GT?
Vin Blanc
Pretty much :D. Boot Google Earth, enter 0N, 28.2 E. Zoom in to ground zero, zoom out to 22000 mls and admire the view :rotfl:
About 307 miles due West of Kompala, Uganda,
logiciel
He doesn't have to but he can if he wants to.
No, we can't.
You don't have to go to Crete to find people who dislike errors in text - Yorkshire will find you one.
AVF doesn't mind the errors - and the idiosyncrasies - though and expects posters not to comment on them.
GloopyJon
If you can install the dish higher up, that will help with the line of sight. For instance, if you can install it at a height of 20 feet, the effective height of the trees will only be 30 feet instead of 50 feet. Dishpointer will tell you if that's ok.
Trending threads
Latest News
NAD launches T 758 V3i surround sound receiver
  • By Andy Bassett
  • Published
Sky unveils next tranche of HDR content
  • By Andy Bassett
  • Published
Acoustic Energy launches AE520 flagship speakers
  • By Andy Bassett
  • Published
Disney drops all 20th Century Fox branding
  • By Andy Bassett
  • Published
Kitsound launches Funk 25 wireless earphones
  • By Andy Bassett
  • Published
