Installing drivers
Discussion in 'Desktop & Laptop Computers Forum' started by Brogan, Jul 9, 2004.
  1. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    When installing a new piece of hardware, is it better to install the drivers first or hardware first?
    In the specific case when the driver is an .exe file, when Windows 'searches for a driver', obviously it can't find it.
    In this instance is it better to
    A: run the .exe file first then shutdown and install the hardware or
    B: install the hardware, cancel the Windows auto search and run the .exe file?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Install the hardware first unless otherwise told. :)
    Often the installation of the driver involves the software probing for hardware of that type. True, Windows tries to be helpful by searching for the driver, it usually allows you to Browse for the installer if it [Windows] can't find it automatically. If all else fails, Cancel out of the New Hardware Wizard and run the .EXE manually, as per your option B.
    Very rarely a driver installer says it needs to be run before installing the hardware, but IMX that is very rare.
  3. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Thanks for that.
    I thought that was the case but thought I'd double check.
  4. The Dude
    The Dude
    May 21, 2004
    6,270
    Beverley, East Yorkshire
    +2,594
    USB devices such as scanners / printers / cameras are the only things that generally need the driver installing first..
  5. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Thanks Dude.
    Now can you help me with my other thread about my RAID controller? :lease:
