Installing BitDefender (Mac)
Discussion in 'Computer Software & Operating Systems' started by srp1969, Mar 5, 2018.
Tags:
  1. srp1969
    srp1969
    Feb 12, 2009
    4
    Hi all
    Sorry to bother you, but I’ve hit a dead end with this and it’s twisting my melon (man)!
    I decided to install BitDefender for Mac the other day. I appreciate the whole debate about whether antivirus is helpful/a negative for Macs etc, but I’m very anxious when it comes to online security and felt I had to get a substantial package.
    I can download the installer and run it, but when I get to the “Installing antivirus for Mac” dialogue box, it just hangs there for hours. My internet connection is good.
    I have removed other security software, though I do have chrome extensions and have still got Malware bytes on there.
    Has anyone experienced similar and resolved it?
    I have googled for answer and haven’t heard anything fro their customer support.
    Any help/advice would be gratefully received.
    Si
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,883
    Norfolk
    +2,531
    Are you using a version of Mac OS compatible with it?
  3. srp1969
    srp1969
    Feb 12, 2009
    4
    Thanks so much for the reply.
    I’m using El Capitan 10.11.6
    Apparently that should be compatible. I might try updating though, just in case.
    Thanks again - appreciated.
    Si
