Installing a Radio
Discussion in 'Portable Disc & Media Players & Recorders' started by MrMikeh, Apr 27, 2005.
  1. MrMikeh
    MrMikeh
    Hey all, New to these boards so sorry in advance if this is the wrong section
    Im installing a car radio with no instructions, I've managed to wire all the speakers up and seem to have two wires left.
    They are a Blue and White one and a Orange and White one.
    I've done some searching on the net and found that there for Illumination and Auto Aerial. Are these important or can I just insulate them with tape and ignore them?
  2. Mr_tickle_007
    Mr_tickle_007
    The Auto Areal cable can just be left its for an automatica arial the old type that use to rise when you turn the stereo on. Just tape up the end.
    Not sure what the other one is I could guess but that dosnt help you much, tape it up and try the stereo, you wond damage any thing if you dont connect it.
    Phil
  3. btiffin
    btiffin
    Illumination is for when you turn your headlights on, the unit will dim its lights. :thumbsup:
