Installing a Draper Luma 8' Screen
Discussion in 'Projectors, Screens & Video Processors' started by Ellispa, Jun 18, 2004.
  1. Ellispa
    Ellispa
    Aug 17, 2002
    182
    +13
    Hi All
    Just got one of these screens, and am a bit surprised by the relatively weak looking fixings for what i think is quite a heavy piece of kit.
    Basically, there are 2 screw holes on either end of the screen, and thats it!
    My plan is to attach it direct to the wall (its a new house, so its a plasterboard, flat wall), and I'm concerned that only 2 fixings isn't really enough, especially with all the pulling down and up that will be going on (assuming I don't get too lazy and leave the damn thing down all the time!).
    So anyone got one fixed in this way? Is it safe? (Don't worry, I'm not pulling any teeth out here!). Does it feel secure etc.
    I could be worrying about nothing, but before I put it up, a little reassurance wouldn't go amiss.
    Thanks in advance etc etc.
    Paul
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,794
    87
    Newcastle
    +116
    Mine was fixed that way and remained on the wall for a year. So yeh, no problem
  3. 2 Point
    2 Point
    I've got the same screen.
    Attached to plasterboard wall with spring toggle mounting screws to try and spread the load a little.
    No problems once it's up, stable and after checking a few times no movement from wall.
  4. Ellispa
    Ellispa
    Aug 17, 2002
    182
    +13
    Thanks both. You've put my mind at ease.
    Now to find out what the hell spring toggle mounted screws are. I'm sure Focus will sort me out.
    Thanks again.
    Paul
  5. 337GUS
    337GUS
    Nov 1, 2000
    756
    NE Scotland
    +39
