EvilMonkey003
I built a custom theatre in a new build and I trusted the company setting up my speakers to get it right.
My brief was that I didn't want anything sitting on the floor if possible other than the sub. I have a 7.1.4 atmos setup with a denon x6700h but what they have done is put my surrounds in the ceiling the same height as my overhead speakers. They are also inline with the overhead ones.
Everything is in wall. It looks awesome but I am pretty sure the sound isn't right with the surrounds on the roof. I called him and he is on holiday right now so he quickly said he could angle them to bounce off the walls. The reason he didn't install them in the walls is because the right side has an indent for kind of like a snack bar etc so they couldn't really go in the wall. They would be too far forward if done in front of the indent.
Is there any way to make this sound good with the speakers in the roof like that? Technically I could probably get some surface/floor mounted ones setup if I really had to but it would mean cutting into drywall and repainting etc. Is this my best option is is there some other way to salvage this? All my cabling is mostly inaccessible and goes to another room in the house so adding cabling could be difficult as it may require the roof iron to be lifted.
Sorry if my diagram is messy
