Installers in Norfolk?
Discussion in 'Home Cinema Buying & Building' started by Bernard Barnett, Nov 24, 2004.
  1. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Next year I shall be moving to Norfolk and would like to know of any high-class AV specialist dealers/installers who are either based there or cover the county. I've done a web search but it didn't produce anything. Does anyone know of any? Many thanks for any advice.
  2. avanzato
    avanzato
    Jan 21, 2003
    1,874
    Norfolk
    +60
    Hmm Norfolk isn't noted for it's huge choice in anything but there are some HiFI places left.
    Off the top of my head the HiFi dealers that are still around are 'Martins', 'Norwich Home Cinema' and 'Sevenoaks' all in Norwich. Norwich Home Cinema does installs and I would think Martins do as well, there is a B&O centre in the city and also a Home automation place called Cyber Select.
    Out of the city there is Basically Sound who IMO are a bit snobby to deal with but do Naim, Linn etc. and CRT Projectors is in the north of the county somewhere. There is also Audio Images in Lowestoft who have some slightly more off beat equipment (some of it very High end) who are also worth visiting.
    HTH
  3. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Thanks Mat. That's really helpful.
  4. bobbypunk
    bobbypunk
    Depends on the level you want, PM me with an idea of the kind of level of kit you are after and where roughly where in Norfolk you would be living and I might be able to add a suitable dealer that hasn't been mentioned but if not might be able to at least tell you which of the recommended above may be most suitable.
  5. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    The Edge sound and vision are in Suffolk but may come to you... www.edge-sv.co.uk
    they're really helpful and professional guys.
  6. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Many thanks folks.
  7. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Moving plans somewhat delayed as we've bought a house but it's going to take a long time to make a start on remodelling. Probably won't be ready to explore AV options until next year now.
