Hi, Im getting rubbish TV reception and need someone in the Essex area (Brentwood) to help me fit a Areal to the chimney pot/brest. I have the aerial here but just needs fitting to the roof and to cable it into my bedroom so I can watch alot of sport on my freeview box Anyone Thanks
Does anyone know what I can expect to pay for this? just putting it up and wiring it into me room. cheers
Do a search on the CAI site for your local instalers and then give 3 or 4 of them a ring for quotes. I had a new arial instaled and fitted for £100. That was the arial, fitting, making sure that it is all tuned in , cable, and including VAT. Shuold be less than that if you are not buying the arial from them
any one else had some one to install an aerial and cable in Chelmsford, Brentwood, Basildon or anywhere near these areas?
9761 a mates brother does arial instals, havent seen him for years but i think then it was about £80. ( working out of basildon at the time) yell.com for an arial installer, theres not that much too it. Im not sure its possible to get a bad one... unless someone knows different
