Installer connected my Panasonic500 correctly?
Discussion in 'Plasma TVs' started by kevin harrison, Jun 9, 2005.
  1. kevin harrison
    kevin harrison
    Just wondering if my installer has installed my Panasonic500 correctly
    SKY+ > RGB 1
    DVD PANASONIC DMRES10 > COMPONENT
    SKY+ > DMRES10 ( TO ENABLE RECORDING )
    I was told that Sky via component this way would look fantastic but it is terrible compared to RGB
    The DVD player via component looks great but Sky looks wrong.
  2. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    you need to connect sky+ from the rgb scart to the dvdr and then dvdr to screen via component...sky doesn't need to go to direct to screen and only one scart is rgb enabled on sky+ anyway. Also make sure sky is set to rgb
  3. Korum
    Korum
    Feb 19, 2005
    4,281
    Stockton-on-Tees
    +704
    Both my Sky+ scarts are RGB enabled, I run a gamecube through it in crystal clear RGB.
  4. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    the other (vcr) is only rgb for input / pass thru not output
  5. greyhorse
    greyhorse
    Apr 16, 2005
    445
    Connect sky > dmres10,
    dmres > scart 2 TV OR
    dmres > component TV
  6. kevin harrison
    kevin harrison
    They had messed the connections up. I've done what's suggested above...
    I've done both of the above, so my dmres goes directly into component so I can watch dvd's in component. Would that be correct?
  7. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    yes.......and sky via component too!
  8. kevin harrison
    kevin harrison
    Thanks. This way Sky looks better via component than before.
    One other question, will it matter having to leave my DVD switched on all the time? If I switch it off Sky via component doesn't work.
    Even leaving it in standby doesn't work.
  9. Mep
    Mep
    Dec 25, 2004
    9,578
    Surrey
    +474
    no its fine.....well mine is the same on my pw7 and its always on and have had no probs (sorry when i answered prev thread i did say standby......should have double checked) and it should look better as i think before you were running the vcr link into the dvdr which is not rgb out
