Installed second Nebula and now no channels
Discussion in 'Microsoft Windows' started by HiZ, Sep 2, 2005.
  1. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    Installed my second nebula card and now I cant watch any tv programs. Tried to re-scan and don't find any. Removed one card and did a re-tune and all is OK.
    Whats going on?
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Did you remove and reload your software?
  3. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    What do you mean, the drivers or XPMCE?
    Oly tried rolling back drivers to 1.32 as 1.36 has given me trouble when searching for new channels in the past. Lets hope i dont have to re-install XP!
    Also tried to re-run the wizzard but no luck. Disabled the seconds card and now Im happy watching F1....
    Damm expensive cards, should have bought some BlackGold's
  4. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    Anyone????
  5. 9761
    9761
    May 16, 2005
    499
    do you have to move a jumper on one of the cards as master and slave?
    Only a guess tho
  6. The Dude
    The Dude
    May 21, 2004
    4,822
    Beverley, East Yorkshire
    +1,169
    have you installed 2 x pci cards, or 1 pci and one of the usb slave units?
  7. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    2 x PCI cards
  8. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    If 2 of these cards can work together then my instinct would be to follow the installation guide again from scratch, i.e. uninstall any controlling software, install cards then install software and go through set up procedure.
  9. The Dude
    The Dude
    May 21, 2004
    4,822
    +1,169
    I'm not 100% sure that you can run two of the pci cards in one machine... their slave tuner for dual-tuner config is available in USB only...?
    might be worth asking Nebula, their support is very good, they'll soon let you know.
  10. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    If i can't use two of these cards, can I use two of another make or an I better to use two different type. Flog one on ebay and buy a BlackGold maybe?
  11. The Dude
    The Dude
    May 21, 2004
    4,822
    +1,169
    I can't help on that point, but there will be people around here running dual-tuner setups I'd have thought....
  12. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I read somewhere that dual tuner support was restricted to one digital and one analogue or two analogue tuners though I seem to remember there were imminent fixes. If anyone is running dual tuners would they care to post their configs and experiences?
