Installed Google Chrome,double click, nothing?
Discussion in 'General Chat' started by muffins, Aug 5, 2013.
  1. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
    Just tried to install it on my Vista 64 bit machine and it seems to install but when I try to use it nothing happens.
    Any insight would be great.
  2. Begonia
    Begonia
    Nov 19, 2006
    3,084
    Northampton
    +647
    Well, for a start, uninstall Chrome and install a much improved version of Chrome, called CoolNovo. They do say that it will run OK on Vista.
    You can get it at: CoolNovo Browser - Formerly ChromePlus, fast and safe web browser with IE Tab
    Next, to ensure absolutely all of your software is slap bang up to date and that you are using the very latest version, try using Secunia PSI (PSI = Personal Software Inspector). Works on Microsoft Windows Vista SP 1 or later.
    You can get this at: Free Security Software Download - (PSI) - Secunia
  3. TheAdmiralCS
    TheAdmiralCS
    Jan 4, 2006
    3,411
    Barnsley
    +1,238
    Surely for a start, get rid of Vista and install Win7 ;)
  4. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
    I did try. I bought an upgrade disc from tesco a while back. Set if off and at the end it said upgrade not guaranteed due to some setting in the bios.
    I said stuff that. Rolled back and returned the disc.
    Once this pc dies I'm hoping to move to a mac.
  5. snaithg
    snaithg
    Apr 7, 2006
    3,187
    +623
  6. Rock Danger
    Rock Danger
    Oct 10, 2007
    11,371
    2
    Belfast - Northern Ireland
    +5,130
    Warning! Mcafee "sucks"
    The site is fine.
    Surely you could unistall chrome, restart, download it again, install.
    If it doesn't work again, the ctrl+alt+del and see if if chrome32.exe is running in task manager.
  7. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
    Can't try coolnovo at the moment. I've deleted and reinstalled chrome and it just doesn't run or show up in the task manager.
  8. reiteration
    reiteration
    Mar 21, 2012
    10,443
    +9,285
    you need to get with it ;)
  9. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
    No idea...
  10. Rock Danger
    Rock Danger
    Oct 10, 2007
    11,371
    2
    +5,130
    Are you using the same install file?
    Did you clear your temp directory?
    Having you tried deleting some of the hidden folders that a failed chrome install would leave behind? in places like
    C:\Users\NAME\AppData\Local\Google\Chrome
    An overly sensitive security suite perhaps?
  11. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
    I've done all that. I even disabled my anti virus nothing changes. I guess I'm just destined not to use chrome. :thumbsdow
  12. Rock Danger
    Rock Danger
    Oct 10, 2007
    11,371
    2
    +5,130
  13. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
  14. muffins
    muffins
    Feb 1, 2008
    2,952
    +301
    This worked. I wonder why this worked and chrome didn't?
    I assume this browser is safe? No back doors for some Chines hacker?
    Didn't work.
  15. Begonia
    Begonia
    Nov 19, 2006
    3,084
    Northampton
    +647
  16. snaithg
    snaithg
    Apr 7, 2006
    3,187
    +623
    Thanks Begonia, Mcafee likes this site just fine, unlike your earlier link which is still rejected by Mcafee.
    I just might try this browser as I am having a few problems with Chrome! Can CoolNovo be installed alongside Chrome or does Chrome need to be uninstalled first?
    Graham.
  17. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Wouldn't touch that CoolNovo with a barge pole. Never heard of it.
    Make sure you install Chrome with full elevated administrator privileges.
  18. Begonia
    Begonia
    Nov 19, 2006
    3,084
    Northampton
    +647
    Yes.
    Hmmm? What else haven't you heard of?
  19. snaithg
    snaithg
    Apr 7, 2006
    3,187
    +623
    Thanks Begonia, I might give it a go!
    Graham.
  20. AnimalOfAnarchy
    AnimalOfAnarchy
    Sep 25, 2011
    381
    Brum
    +30
    I've been having so many problems with Google Chrome so I uninstalled it and installed Mozilla Firefox. I've not looked back, it runs like a dream!
